2 members (ShopRag, FishinToms53), 93 guests, and 0 robots.
Topics128,049
Posts1,055,634
#678056 09/16/2010 2:15 PM
After converting my ’41 to 12 volts my 6V horn still works but sounds somewhat anemic. I’m looking for suggestions for a 12V horn that looks close to the stock 6V unit and can be mounted on the intake manifold.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #678108 09/16/2010 5:07 PM
I think your horn needs an adjustment. My six volt horn is really loud on 12 volts.
1951 1 Ton Completed
Ex Hall Monitor
Ex Hall Monitor
Ditto, a 6v horn on 12v should be a lot louder.
Tiny #678283 09/17/2010 6:02 AM
try filing the vibrator points......
GMC: Get More Cash...
1958 GMC
My Webshots photos
I'm also interested to learn of an aftermarket 12v horn that looks and sounds like the original horn.
So, going back to the original question, does anyone have a recommendation for a source for original looking horns? I have no problem finding original sounding horns, but they don't look much like the broken original that I replaced with a cheap aftermarket.
TxLaTx #678328 09/17/2010 2:27 PM
if the new one was cheap it might be worth a try to take it apart and put the guts in the case of the old one - if it doesn't work you're not out much - find a working original
squeeze #678351 09/17/2010 4:01 PM
I
I Offline
Good idea, putting new guts in old case. I'll try that sometime.
InTow #678401 09/17/2010 6:02 PM
I bought a $15 horn at O'Reilly. Works great, sounds great. It doesn't look that out of place, either.
chicklin #678577 09/18/2010 12:29 PM
Put an ad in Truck Parts Wanted. You can get used horns that work for a reasonable price.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
I will pull my horn apart and see what there is to adjust. Otherwise I'm still looking for a 12V unit that looks like this
http://rides.webshots.com/photo/2203253310101330996eNoiMx
Kip's41 #678641 09/18/2010 6:31 PM
You won't find a 12V like that on a Chevrolet.
Cletis #679364 09/21/2010 3:17 AM
Kip,
For what it's worth, when I had my '46 (with a '41 cab, so whatever) rewired the guy that did the work suggested I install mid 70's Ford (ugh!) twin horns. They are LOUD and sound right. They look much like the ones in the link from TxLaTx above but I put them behind the grill instead of in the engine compartment. Besides, I've got a 350/350 and IFS/IRS so authenticity is no longer an issue.
Thanks guys.
I have adjusted mine and it is a little better. It's not so much the loudness but the sound it makes. It sounds more like ahhhhhhhhhhhh than toot. I tried the horn with my old 6V battery and the sound is about the same
The truck is mostly stock and I would like to keep the horn where it is bolted to the manifold.
Kip's41 #679501 09/21/2010 7:44 PM
Someone had put a "meep-meep" horn on my burb. I found a pair of 6V Olds horns at a swap meet. They sound off nicely on 12V.
Cletis #679674 09/22/2010 7:08 AM
I pulled a pair off a mid-70's/80's chevy truck at the salvage yard, mounted them under the "hood latch pan", and they sound like caddy horns. Don't forget to get about 8-10 feet of the wire with them.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
