5 members (55shaker, TUTS 59, 2-Ton, jmoore, dunfire), 108 guests, and 1 robot.
Topics128,048
Posts1,055,541
Members48,425
#677804 09/15/2010 8:41 AM
1 Offline
guys, getting the engine (327) ready to remove and noticed the bellhousing was different than a standard sbc, much larger. my question is are their and hidden bolts i need to remove before the engine will separate from transmission? thanks!
Riding in the Passing Lane
No. It unbolts like any V-8. There is a mounting plate attached to the engine to accept the larger houseing. That's where that upper hole in the pattern on truck engines comes in.
1972 Chevy c10 Cheyenne Super
1 Offline
it came of smooth today. thanks.
1 Offline
does anyone know what starter the C-60 came with? it seems to have a configuration i have never seen. the bellhousing is huge and the transmission has 1.5" input shaft with 13" clutch disc/pressure plate.
That is probably a larger bellhousing and adapter for it so you can use a larger flywheel and clutch. Unless you'll be putting it in another big truck you may want to downsize.
I'm certainly not a gas engine or V8 expert, but I've seen the larger setups in the bigger trucks, that may be what you have?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
It may well be a double disc clutch which won't fit a pickup. However the block is the same and a pickup clutch housing and flywheel will fit the engine.
10micron is not using the bell housing starter and flywheel I am it will be staying in the C60 that the 327 came from I believe that he is asking the starter question for me. I however not only need a starter for this setup I would sure like a 16.5" flywheel for a 454 to go with this setup.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
If he is just looking for a starter, a 1108485 Delco will work and they are available. They fit Chev and GMC medium trucks from the late 50's until the mid 70's and possibly later.
