| | | Forums66 Topics128,047 Posts1,055,534 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | guys, getting the engine (327) ready to remove and noticed the bellhousing was different than a standard sbc, much larger. my question is are their and hidden bolts i need to remove before the engine will separate from transmission? thanks! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | No. It unbolts like any V-8. There is a mounting plate attached to the engine to accept the larger houseing. That's where that upper hole in the pattern on truck engines comes in. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | it came of smooth today. thanks. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | does anyone know what starter the C-60 came with? it seems to have a configuration i have never seen. the bellhousing is huge and the transmission has 1.5" input shaft with 13" clutch disc/pressure plate. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | That is probably a larger bellhousing and adapter for it so you can use a larger flywheel and clutch. Unless you'll be putting it in another big truck you may want to downsize. I'm certainly not a gas engine or V8 expert, but I've seen the larger setups in the bigger trucks, that may be what you have?
Grigg | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | It may well be a double disc clutch which won't fit a pickup. However the block is the same and a pickup clutch housing and flywheel will fit the engine. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | 10micron is not using the bell housing starter and flywheel I am it will be staying in the C60 that the 327 came from I believe that he is asking the starter question for me. I however not only need a starter for this setup I would sure like a 16.5" flywheel for a 454 to go with this setup. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If he is just looking for a starter, a 1108485 Delco will work and they are available. They fit Chev and GMC medium trucks from the late 50's until the mid 70's and possibly later. | | |
