0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | Hey guys. What size jets should I be running in my 2g carb on my 61 283 stock other than an hei down here in florida. its running rich and I have the idle screws all the way in which is where it runs the best. I don't know what size is in there and I didn't want to take it apart until I got some new ones which I have to order. If I do have to take it apart does it tell me what size they are or do I have to measre? do I just check the diameter of the hole. Jetting is definetly not my area. | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | If it has suddenly gotten rich, it's probably not a jetting problem. Chances are you've got a leaky needle valve/seat assembly, or a float that has gotten some gas in it and can't seal the incoming gas well enough to keep the fuel level in the float chamber correct. A high fuel level will result in a rich-running condition. You could also have a sticky power valve that's letting fuel bypass the main jets. Either, or both conditions will make the engine run very rich and use lots of gas! Jerry
| | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | its been rich as long as I have had it. I have had it apart a couple of times and jetting is the last thing it could be. the po lived in north carolina when he had a new carb put on it so I am thinking that it was jetted for a higher elivation | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Replacement jets for a 2G aren't very common parts. Somebody like CarbKing might be able to help you out. If you use a set of number drills and get a guesstimate of the size jets that are in there now, that would be the only way I know to figure out which way to jump for a leaner mixture. Jerry
| | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | thanks jerry I work in a machine shop so I can just pop them out and check them with a pin gage. I found a place that sells individual parts online finally. Thats why its been rich for so long. I couldn't find anyone who sold them. I read somewhere to try two sizes smaller if its to rich. Is that .002 thousanths? | | | | | Joined: Feb 2000 Posts: 5,198 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,198 | Those jets should be numbered.
Carburetor model B, BC, BV, 2G,2GC,4G,4GC are all in the group "A" jets. In this group are three different styles, a 90 degree square cut, a 60 degree approach angle short taper, and a 60 degree approach angle long taper. All three will interchange, just stay in the same sub group. Each jet is stamped with the orifice diameter, which may or may not be the true diameter of the hole. But a decrease in numbers will decrease the size, same for going larger.
By looking in the top side of the jet, you can see the difference in the three styles. Going from the largest hole in the jet to the actual jet orifice, the angle and length of the taper cut is the difference, it effects the fuel flow through them
Joe
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It probably has 53-55 in it. They are stamped but when you are my age you need a magnifying glass to read it. It is thousands. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | thanks guys. I will take um out and see what the are | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | it was jetted for a higher elivation
If it was, it would be jetted leaner. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Just a chance: your vacuum piston is carboned up, and the metering rod is stuck in the "up" position (full rich). | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 2G doesn't use a metering rod but the power piston could be stuck or the vacuum passages to it are blocked. The vacuum holds the piston up till the vacuum gets low under accel. & the piston drops to give power enrichment. I would put my money on an incorrect float setting or a float with gas in it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
