3 members (delky, Hotrod Lincoln, Rich'sToys), 78 guests, and 0 robots.
Topics128,049
Posts1,055,740
#677000 09/11/2010 4:05 AM
Z
Z Offline
Will a saginaw 3 speed transmission from a 69 C10, 250 fit a 66 with the same engine and transmission.
Kinda anwered your own question...
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!"
Elanor Roosevelt
1966 c-10 stepside
1966 c-10 fleetside
1964 c-10 fleetside
1964 c-10 short bed
1964 c-30 flat bed
1964 c-60 dump truck
1968 Impala
1969 Nova
1971 Nova
1975 LUV
1976 C-30
1977 K-20
1966 SS El Camino
David13 #677083 09/11/2010 3:11 PM
zanemobile, are the 3spd trans identical?
Or is the 66 a Saginaw, and the 69 a later all synchro Muncie. The 69 should bolt right in providing the spline count on the input shaft is the same. There maybe a question as to whether the shift linkage will work.
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #677098 09/11/2010 3:59 PM
the linkage should be the same but like Larry points out, the difference in the pre and post 68 trannys [nonsyncro and syncro] will be the spline count, you'll need to change the driveshaft slip yoke, not to big a deal if you can find one
