Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Bill Marlow, Otto Skorzeny, baldeagle, EchoBravoSierra, Jon G, Jeff Ogden), 38 guests, and 3 robots.
Topics128,005
Posts1,055,266
Members48,418
#676926 09/10/2010 10:22 PM
How do I remove the dipstick assembly from a 1965 230 cid engine block?
Thanks in advance.
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
Nesto426 #677064 09/11/2010 1:54 PM
most of them are just pushed into a hole. Grab it with a pair of pliers and twist and pull.
Larry
58 gmc 100 with 350 sbc
LarryW #677069 09/11/2010 2:18 PM
if they are real stubborn you can snap on some vice grips and use a slide hammer. it will collapse the tube so leave it as a last resort.
hoggyrubber #677080 09/11/2010 3:04 PM
I've made a pulling adapter by drilling a hole in a short piece of 1 inch diameter round stock just big enough to slip over the tube, and then slotting it with a hacksaw. Slip it over the tube, then grab it tightly with vise grips and use a hammer to tap it out of the block. Works well, and doesn't damage the tube!
Hotrod Lincoln #677101 09/11/2010 4:09 PM
In most cases the tube is 5/16" ID. I put a 5/16" bolt or rod inside before I grab with Vice-grips, so the tube will not collapse.
My Blog
Pre '68 Dave #677340 09/12/2010 3:26 PM
Thanks everyone. I'll work on it.
Tom
Nesto426 #686846 10/17/2010 4:34 AM
The screw driver trick work just fine. I forgot to reply. Thanks again!
Tom
Nesto426 #686887 10/17/2010 1:27 PM
Now Jerry I’ve been around engines laying in pieces for 68 years and that’s the first time I’ve heard of that trick, great idea. A few minutes on the lathe and I’ll have a new tip for my slide hammer. Before I took my short block up to the engine shop I tried to figure a good way to get it out with out destroying it. Back in the day we would just yank them out and then when we stopped by the Chevy parts department we would have them throw one in with the other parts for our rebuild.
tks
DG
Denny G
Sandwich, IL
