7 members (Shaffer's1950, 54farmtruck, Southerntruck, Lightholder's Dad, Pre '68 Dave, Donf, rfs56trk), 126 guests, and 1 robot.
Topics128,189
Posts1,057,337
Members48,469
have 52 and 54 chevy 1/2 trucks both to have 235 engines and langdon built t-5s.The question is do I need a transmission brace or any modifications to stabilize .I've got a 49 chevy 3/4 ready to place a 261 and a t-5 and the question is the same --any braces needed?Thanks as usual.Sid Stephenson
I'm not going to tell you that you have to use a rear transmission mount, but if you look at the T-5, it has provisions for a rear mount. That tells me that it would be best to use one.
In the case of my 37, I use the original cross member the original transmission mounted on and, with some minor alterations, it worked great.
Riding in the Passing Lane
I alway's put a universal crossmember under mine with a mount. Some guy's say they run without one but I can't see letting that long aluminum case hang there. Look at all the braces the factory put's on the T-5's.
1972 Chevy c10 Cheyenne Super
Think about it .....that front aluminum transmission flange holding that T-5 onto the adapter plate is pretty soft stuff.
I would think the vibration from the driveshaft and no mount would tear it up.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
