| | | Forums66 Topics128,186 Posts1,057,315 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 27 | have 52 and 54 chevy 1/2 trucks both to have 235 engines and langdon built t-5s.The question is do I need a transmission brace or any modifications to stabilize .I've got a 49 chevy 3/4 ready to place a 261 and a t-5 and the question is the same --any braces needed?Thanks as usual.Sid Stephenson | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I'm not going to tell you that you have to use a rear transmission mount, but if you look at the T-5, it has provisions for a rear mount. That tells me that it would be best to use one. In the case of my 37, I use the original cross member the original transmission mounted on and, with some minor alterations, it worked great.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I alway's put a universal crossmember under mine with a mount. Some guy's say they run without one but I can't see letting that long aluminum case hang there. Look at all the braces the factory put's on the T-5's. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Think about it .....that front aluminum transmission flange holding that T-5 onto the adapter plate is pretty soft stuff.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I would think the vibration from the driveshaft and no mount would tear it up.
