0 members (),
54
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 8 New Guy | | New Guy Joined: Aug 2010 Posts: 8 | Will a saginaw 3 speed transmission from a 69 C10, 250 fit a 66 with the same engine and transmission. | | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | Kinda anwered your own question...
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" Elanor Roosevelt
1966 c-10 stepside 1966 c-10 fleetside 1964 c-10 fleetside 1964 c-10 short bed 1964 c-30 flat bed 1964 c-60 dump truck 1968 Impala 1969 Nova 1971 Nova 1975 LUV 1976 C-30 1977 K-20 1966 SS El Camino
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | zanemobile, are the 3spd trans identical?
Or is the 66 a Saginaw, and the 69 a later all synchro Muncie. The 69 should bolt right in providing the spline count on the input shaft is the same. There maybe a question as to whether the shift linkage will work.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the linkage should be the same but like Larry points out, the difference in the pre and post 68 trannys [nonsyncro and syncro] will be the spline count, you'll need to change the driveshaft slip yoke, not to big a deal if you can find one
Bill | | |
