1 members (Samantha), 45 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
Fox
Offline
I tried to email a guy named Bruce (aka Phat) but he hasn't replied in about two weeks. I was wondering if a 1/2 ton Chev rearend from a 81-87 might work in my 50 1/2 ton. Are these worth the trouble? Do they even fit somewhat? I measured one from flange to flange, I think it was about 57 inches. On the 50, its rear was about the same. I just need confirmation, and advice from someone who has done this swap.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I installed a 81 Chevy 1/2 rear in my 51 Chevy 1/2 6 years ago.Used the 4x4 rear axle so it has the 6 lug pattern to match the front in my case.The axle looks fine ,its only about an inch and a half wider than the stock set up.You have to set up the axle with the correct pinion angle, then weld up the new spring perches.Have a driveshaft made, new U bolts and of course change out the old torque tube transmission to a tranny from a later model GM vehicle. There are a few odds and ends I didn't mention, you'll figue it out.I had never swapped in a axle from a different vehicle before ,but it was no problem at all.
Fox
Offline
Thanks Tony, you are a savior. Been trying to find someone who's done this. Thanks a lot. grin
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
1 Offline
I installed a 67 1/2 ton rear end in my 48 panel. wasn't to hard. The hardest was the pinion angle.Needs to to be real close, or you go through many a ujoint I was lucky and had the trany end piece to go to the open drive line. Used the drive shaft out of an 62 Chevy 1/2 ton had to have it shortend and balanced.
Good luck.
Been driven and loving my 50 for 27 years. With the same stuff Chevy put in it from the get go.
most parts store's supply wedge shims of severel diferent angle's to fix the angle so it is not so hard to replace spring pads
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
