0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 |
In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Lookin' good David. It's a great day when things start to come together again. You're doing an outstanding job, keep it up! Jock  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Looks good! I just got my clip test fit today and I'm feeling pretty darned good too! It's all downhill from here!
BTW, Is that a Clifford/Holley setup on your engine? | | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | yes. it's a clifford/holley. I like holleys, but the clifford intake leaks coolant (tried 2 different intakes brand new). It just seeps through the pores of the casting to the inside and outside of the intake. So I don't use the coolant to heat it. It runs just fine in the winter. Can't say too much about it. The only load I'm able to put on it now is just going through the gears while on jack stands.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | David, fantastic looking job. I truly understand what you mean by it looking like a truck now..... but just wait until you set the bed on it!!! Then it will be like WOW. Good job to the details. One nice truck. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | | | | | | Joined: Feb 2000 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 38 | Lookin' good! Thanks for the pics. | | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | I'm jealous! Yours is looking great! How did you secure the wood to the engine hoist to lit the cab up? I'm painting my cab this weekend & will be following in your footsteps soon. Thanks for the photos. | | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | I didn't. I put something soft like a towel between the wood and the cab to prevent scratching. I used two 2-by-8 boards. I had to lift a little, then re-adjust a few times before finding the center point. After I was satisfied with the balancing, I lifted and pushed it over the frame. Take the step rail OFF. when its balancing on the engine hoist, you are not going to want to waste to much time, just because all the hard work is up in the air. I realized that the engine hoist won't roll far enough under the frame with the side step on. It did do some wobbling and if a 2nd person is available it would help to prevent that. There was no sliding on the wood though. But I would go with 8 inch wide wood at least. When I took the cab off, I used one board and it worked, but the board did some bending and made me nervous. It took be a little over an hour to put it on by myself.
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | | | |
