4 members (Charles in CA, 52Carl, bluechev, TooMany2count), 74 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#676837 09/09/2010 3:26 AM
Apprentice
Apprentice
when i bought my 65 GMC some yahoo decided that he wanted to put some extra gauges in with the other ones and it looks like you know what.My question is can i put a chevy one in there and what year would it be.My ignition is not in with the gauge panel any help would be appreciated
thanks chip
1965 GMC 1/2-Ton Short Box Stepside
More pix on Photobucket
HeavyChevys #676944 09/10/2010 11:18 PM
The problem is going to be the wiring harness. The dash would probably fit, but chasing wires would be a PITA. Check Jolly's GMC web site;
http://www.6066gmcguy.org/MyStory.htm
How does the wire harness look, have the PO hacked it up?
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #677212 09/12/2010 1:04 AM
From a practical standpoint I don't believe any 60-66 Chevy gauge panel will fit in any 60-66 GMC. The opening in the GMC dash is wider and shorter. In the entire series GMC's only had two types of panels, the earlier metal pan with a small cluster in the center, and the later design with a plastic bezel.
Here's a link showing the different types:
http://www.6066gmcguy.org/cluster.htm
Depending on your budget, here's a very expensive restored unit:
http://www.bowtiebits.com/store/sto...amp;Category_ID=4&Sub_Category_ID=74
Here's an outfit that makes custom GMC panels. Just click Chevy/GMC trucks, and keep clicking until you get to the GMC entry:
http://www.boeseengineering.com/
And here's a thread showing different custom ideas:
http://67-72chevytrucks.com/vboard/showthread.php?t=360089&highlight=dash+panel
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Markeb #677424 09/12/2010 8:42 PM
Apprentice
Apprentice
thanks for the help guys but i think i will try to do something with my old one or we have a laser at work see if they cant make me something up again thank you
chip
