5 members (3800GUY, Uncles51, Gdads51, J Lucas, Otto Skorzeny), 94 guests, and 2 robots.
Topics128,127
Posts1,056,674
Members48,450
#676403 09/08/2010 12:32 AM
Where and how were the cable operated shut off valves mounted? I bought a new one from Napa and trying to decide where the best place to install it would be.
I could maybe put it inside the cab between the heater and firewall. I have about 4 to 5 inches there.
My second thought is that the original location, wherever that is, had some forethought applied already so there would be no need for me to damage my brain any further to pick a location.
The truck is a 53 Chevy/GMC on a 73 Suburban frame and drivetrain.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
original cable operated valves were the ranco valves with temperature controls that were around the heater in the cab, or later inside the heater box - eventually they all result in water leaking into the cab, usually unnoticed until it was a real mess .... IMO the best place for the more modern style cable operated on/off valves is in the hose just before it goes thru the firewall, if it leaks it's outside
Thanks Bill. I went ahead and installed it between the heater and the firewall. I can operate it by hand for the time being until I fabricate a bracket to attach the cable to next weekend. As part of that operation, I may just take your advice and move it outside.
1953 Chevrolet 3600
Riding in the Passing Lane
You want to put it in the inlet hose.
1972 Chevy c10 Cheyenne Super
OK, why would that matter? It just stops or restricts the flow in the loop doesn't it? I installed it in the hose that goes from the intake on the 350 engine.
1953 Chevrolet 3600
Ex Hall Monitor
Ex Hall Monitor
When it's off it stops the pressure from the water pump on the heater core.
Makes sense, But doesn't the pump suck the water out of the heater core on a small block V8?
You are right, the old heater core doesn't need any extra pressure.
1953 Chevrolet 3600
wouldn't the way to stop having cooling system pressure in the heater core be to shut off both hoses? wink
either hose is part of the same closed system, which makes it worth considering the integrity of the core when choosing a rad pressure cap
