8 members (TexasJim50, Otto Skorzeny, Greg_H, GusG, Lonnie, Nick in Manitou, J Lucas, moparguy),
102
Mod | | | Forums66 Topics128,089 Posts1,056,428 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Hi guys today I found a possible solution for my problem with the rear drum of my 1952 3/4ton. A local foundry. The manager told me that they make the new one with the old one as sample. Have anybody experience in this matter? I want hear something before to proceed. Thanks, Alfonso | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | | | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | thanks Steve, but I´m not from USA and the $200 will be $400 in my country.In the foundry will cost $125 each Alfonso
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | As long as You can trust the outfit and than have the inside turned to spec.thats all a drum is is a casting.
Pete | | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Ok, if I decide to make them, somebody can help me with the inside diameter(thinking that I have to turned according to the original measurements) alfonso | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jim Carter has them for @$150 (still expensive)
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I bought new drums front and rear for the 1/2 Ton Huck setup from Jim Carter. The originals had a cast drum and a steel mounting disc. They were pressed together somehow. The new ones were all cast so the disc was thicker. | | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Thanks Tim, It represent $300 here. I´m still considering the foundry, but they going to ask me the inside diameter like the new one! any idea? thanks Alfonso | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Here are the specs for the 1951: Brake Specs I believe your front drums will be 11" and the inside diameter at exact standard will be 11.000". The reason I mentioned above about the new drums I bought being cast is because the mounting disc is thicker and that sets the whole drum to the outside a bit. In my case they compensated for this. | | |
