4 members (Bisbee, Eileen, Bill Hanlon, Rusty Rod), 145 guests, and 3 robots.
Topics128,089
Posts1,056,439
Members48,443
#676352 09/07/2010 9:49 PM
Hi guys today I found a possible solution for my problem with the rear drum of my 1952 3/4ton. A local foundry.
The manager told me that they make the new one with the old one as sample. Have anybody experience in this matter? I want hear something before to proceed.
Alfonso
How about these ?
Steve
'49 3800
'52 3600
'57 3100
thanks Steve, but I´m not from USA and the $200 will be $400 in my country.In the foundry will cost $125 each
Alfonso
As long as You can trust the outfit and than have the inside turned to spec.thats all a drum is is a casting.
Pete
Ok, if I decide to make them, somebody can help me with the inside diameter(thinking that I have to turned according to the original measurements)
alfonso
Jim Carter has them for @$150 (still expensive)
I bought new drums front and rear for the 1/2 Ton Huck setup from Jim Carter. The originals had a cast drum and a steel mounting disc. They were pressed together somehow. The new ones were all cast so the disc was thicker.
1951 1 Ton Completed
Thanks Tim, It represent $300 here. I´m still considering the foundry, but they going to ask me the inside diameter like the new one! any idea?
thanks
Alfonso
Here are the specs for the 1951: Brake Specs I believe your front drums will be 11" and the inside diameter at exact standard will be 11.000". The reason I mentioned above about the new drums I bought being cast is because the mounting disc is thicker and that sets the whole drum to the outside a bit. In my case they compensated for this.
