| | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | what vehicle can i get rotors off of that will fit my stock 1953 3100 spindles?
thanks john | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | The short answer is none! I believe rotors are used from camaros or 1970s 4wd trucks. The camaro uses a hat to space it out. The 4wd rotor uses the stock hub.
There are kits available complete with every part you would need for short money. Yes, you might be able to come up with something that may or not work on your own. These kits remove all thought, and most chances for error. IMHO they are well worth the money. | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | Thanks for the info guys. i thought i might be able to get some at the junk yard. but it looks like i might have to go with a kit. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Go with a kit. My brother put disks brakes on an axle for which there is no kit available. He has his own lathe and mill and still had to send some parts out to be made.
I'm sure he spent far more than the cost of a kit and far more time than installing the kit.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
