0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#675728 09/05/2010 4:37 PM
what vehicle can i get rotors off of that will fit my stock 1953 3100 spindles?
thanks john
johns truck #675841 09/06/2010 3:34 AM
The short answer is none! I believe rotors are used from camaros or 1970s 4wd trucks. The camaro uses a hat to space it out. The 4wd rotor uses the stock hub.
There are kits available complete with every part you would need for short money. Yes, you might be able to come up with something that may or not work on your own. These kits remove all thought, and most chances for error. IMHO they are well worth the money.
bigbadswingdaddy #675876 09/06/2010 6:17 AM
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
webstershotrods #676065 09/07/2010 1:39 AM
Thanks for the info guys. i thought i might be able to get some at the junk yard. but it looks like i might have to go with a kit.
johns truck #676141 09/07/2010 5:06 AM
Go with a kit. My brother put disks brakes on an axle for which there is no kit available. He has his own lathe and mill and still had to send some parts out to be made.
I'm sure he spent far more than the cost of a kit and far more time than installing the kit.
