1 members (moparguy), 39 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
The flywheel for the original 235 from my '57 3200, which I just rebuilt, is showing some several inch long hairline cracks around the inside of the center hole. I figure it to be scrap. (Correct?) Can I substitute a '58 261 flywheel that I have or will it throw things out of balance? I notice that the 58 261 flywheel has a ring gear on it while the 57 appears to be all one piece. Also one is marked GM40 and the other GM44. Otherwise they look the same. Any help appreciated!
The very best nugget of wisdom anyone could ever offer you in dealing with your wife: You can be happy, OR, you can be right.
The 58 flywheel should work fine. I would get it balanced by a machine shop before installing it then it won't throw things out of balance so much.
Leo Offline
Moderator
Moderator
I did that exact swap also. They were the same.
You may find the timing ball is in a different position. The books I have seen show the timing for a 261 is TDC.
My Blog
