| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 12 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 12 | The flywheel for the original 235 from my '57 3200, which I just rebuilt, is showing some several inch long hairline cracks around the inside of the center hole. I figure it to be scrap. (Correct?) Can I substitute a '58 261 flywheel that I have or will it throw things out of balance? I notice that the 58 261 flywheel has a ring gear on it while the 57 appears to be all one piece. Also one is marked GM40 and the other GM44. Otherwise they look the same. Any help appreciated!
The very best nugget of wisdom anyone could ever offer you in dealing with your wife: You can be happy, OR, you can be right.
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The 58 flywheel should work fine. I would get it balanced by a machine shop before installing it then it won't throw things out of balance so much.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I did that exact swap also. They were the same. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You may find the timing ball is in a different position. The books I have seen show the timing for a 261 is TDC.
See the USA in your vintage Chevrolet! My Blog | | |
