5 members (Gdads51, Barney1951, KEVINSKI, TexasJim50, cmayna), 42 guests, and 0 robots.
Topics128,080
Posts1,055,946
Members48,430
#675971 09/06/2010 7:40 PM
[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
Lookin' good David.
It's a great day when things start to come together again.
You're doing an outstanding job, keep it up!
Jock thumbs_up
More pix on Flickr.
Looks good! I just got my clip test fit today and I'm feeling pretty darned good too! It's all downhill from here!
BTW, Is that a Clifford/Holley setup on your engine?
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
yes. it's a clifford/holley. I like holleys, but the clifford intake leaks coolant (tried 2 different intakes brand new). It just seeps through the pores of the casting to the inside and outside of the intake. So I don't use the coolant to heat it. It runs just fine in the winter. Can't say too much about it. The only load I'm able to put on it now is just going through the gears while on jack stands.
David, fantastic looking job. I truly understand what you mean by it looking like a truck now..... but just wait until you set the bed on it!!! Then it will be like WOW. Good job to the details. One nice truck.
What a great job!
I
I Offline
Lookin' good! Thanks for the pics.
InTow #676945 09/10/2010 11:19 PM
I'm jealous! Yours is looking great! How did you secure the wood to the engine hoist to lit the cab up? I'm painting my cab this weekend & will be following in your footsteps soon. Thanks for the photos.
1937 Chevy pickup
1952 MGTD
I didn't. I put something soft like a towel between the wood and the cab to prevent scratching. I used two 2-by-8 boards. I had to lift a little, then re-adjust a few times before finding the center point. After I was satisfied with the balancing, I lifted and pushed it over the frame. Take the step rail OFF. when its balancing on the engine hoist, you are not going to want to waste to much time, just because all the hard work is up in the air. I realized that the engine hoist won't roll far enough under the frame with the side step on. It did do some wobbling and if a 2nd person is available it would help to prevent that. There was no sliding on the wood though. But I would go with 8 inch wide wood at least. When I took the cab off, I used one board and it worked, but the board did some bending and made me nervous. It took be a little over an hour to put it on by myself.
1 Offline
looks fantastic dude!
