Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 56 guests, and 5 robots.
Topics128,003
Posts1,055,244
Members48,418
#675149 09/03/2010 3:37 AM
I am wondering what you guys have done to test lights and radios, gauges and what nots on the bench. I have thought about rigging up a battery on the side of my bench but have heard something about it is not good to test these things whith a battery. Wondering if someone makes a thing that you can plug into the wall and test 6/12volt items with and not worry about having to keep it charged if this makes sense.
Kenny Broomfield
551st3800 #675158 09/03/2010 3:54 AM
they normally run off a battery, not sure why testing them with a battery would be a problem, tho' it'd be best if you included a proper sized fuse in the power lead .... OTOH, a "thing that plugs in the wall" would be a power supply, quite like a battery charger, and if you've got an older style that doesn't need feedback from a battery, that'd work fine too
squeeze #675207 09/03/2010 11:28 AM
I use a 12v power supply that plugs into ac. It's convenient cause it's small, no acid, wires attach easy, and light to carry around should I need it somewhere else.
Got it years ago and don't remember the cost.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
glasman #675268 09/03/2010 3:03 PM
Riding in the Passing Lane
I keep a garden tractor bat. close by & a bunch of jumper wires. For radios I have a board with an antenna & speaker on it. I have a lomg cord with clips on it to hook to a battery.
1972 Chevy c10 Cheyenne Super
551st3800 #675281 09/03/2010 3:54 PM
Like Glasman said, 12v DC power supply that plugs into the wall (120v AC). They also make adjustable DC power supplies that are inexpensive. You will also need a DVOM.
Good Luck
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
di1953gmc #675558 09/04/2010 6:56 PM
I use the batteries off of my 14V Dewalt drills!
fredoly #676008 09/06/2010 9:39 PM
only reason that I could think that a 12v battery would not work would be on sensitive equipment that is designed to have a resistor or reducer ahead of the unit.
aggie jon #676040 09/06/2010 11:42 PM
Thanks for all the great replies. I think I will go with one of the 12v wall supplies. I also dabble in model trains and was just thinking that one of my transformers would work. I think I can dial the power to what ever I want on them. Will have to get out the DVOM to check everything.
Kenny Broomfield
