4 members (massey1951, 1955 1 Series, sron48, Otto Skorzeny), 91 guests, and 2 robots.
Topics128,038
Posts1,055,583
#670859 08/17/2010 12:01 AM
I picked up these tools from the estate sale of a 50's chevy collector. http://s830.photobucket.com/albums/zz230/19511979chevgmc/tools/ the one that looks like a screwdriver has a piece of tape that says "6 cyl valve adj" is it? and how do I use it?. then theres the big "thing" that I think is for magnafluxing. and a little ratchet, adjuster thingy?? that is stamped "K-D NO.339" any ideas?
Garandboy #670864 08/17/2010 12:35 AM
You would use them both together. the ratchet loosens the nut and the driver adjusts the valve. The other thing, I have no clue.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Those are very rare tools. I think you got them way too cheap.
If that valve adjustment set turns out to be for a Ford Model T, I saw on the H.A.M.B. somebody was looking for one.
1953 Chevrolet 3600
yep Marty, now I just need to figure out how to use them.
I have a screwdriver like that I got from an old Chevrolet mechanic. It makes it so the screwdriver doesn't slide off while adjusting valves with the engine running. I really like mine!
Bruce
My Trucks
Stuff I Collect
I have a screwdriver my dad made that has the blade completely hidden in the metal sleeve. It is for adjusting valves with the engine running so it will not slip off the adjuster while the engine is running. I have used it lots of times before I got the tool with a socket and screwdriver combination for adjusting valves and working the lock nut at the same time.
Moderated by  MNSmith
