| | | Forums66 Topics128,005 Posts1,055,256 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 52 | I am wondering what you guys have done to test lights and radios, gauges and what nots on the bench. I have thought about rigging up a battery on the side of my bench but have heard something about it is not good to test these things whith a battery. Wondering if someone makes a thing that you can plug into the wall and test 6/12volt items with and not worry about having to keep it charged if this makes sense.
Kenny Broomfield | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | they normally run off a battery, not sure why testing them with a battery would be a problem, tho' it'd be best if you included a proper sized fuse in the power lead .... OTOH, a "thing that plugs in the wall" would be a power supply, quite like a battery charger, and if you've got an older style that doesn't need feedback from a battery, that'd work fine too
Bill | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I use a 12v power supply that plugs into ac. It's convenient cause it's small, no acid, wires attach easy, and light to carry around should I need it somewhere else. Got it years ago and don't remember the cost.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I keep a garden tractor bat. close by & a bunch of jumper wires. For radios I have a board with an antenna & speaker on it. I have a lomg cord with clips on it to hook to a battery. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Like Glasman said, 12v DC power supply that plugs into the wall (120v AC). They also make adjustable DC power supplies that are inexpensive. You will also need a DVOM.
Good Luck
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | I use the batteries off of my 14V Dewalt drills! | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | only reason that I could think that a 12v battery would not work would be on sensitive equipment that is designed to have a resistor or reducer ahead of the unit. | | | | | Joined: Feb 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 52 | Thanks for all the great replies. I think I will go with one of the 12v wall supplies. I also dabble in model trains and was just thinking that one of my transformers would work. I think I can dial the power to what ever I want on them. Will have to get out the DVOM to check everything.
