3 members (Pre '68 Dave, 52Carl, Bill Marlow), 50 guests, and 2 robots.
Topics128,090
Posts1,056,028
Members48,432
#675086 09/02/2010 11:53 PM
My '36 low cab has large chrome headlights. 10" across with 9" lenses and they about 8 1/2" deep. What are the correct size headlights? Thanks
Ex Hall Monitor
Ex Hall Monitor
Do you mean what number bulb they use? You already gave the size. ohwell If that was your question and it's still 6v the Filling Station lists this bulb for your application.
I believe that my entire headlight assembly is incorrect for this truck and that the orginal assembly used a 7" headlight and not a 9" headlight.
maplefrm, take a look in at trucks like yours in the gallery and see if anything makes sense. Might try Keith Hardy's on line manuals to see if you can spot anything there. His link is in the tech tips.
Y
yar Offline
Y Offline
Maplefrm, I have a '36 high cab that I have owned since 1965 and restored in the 1970s. I have no computer skills so I don't know how to post pictures here. If you give me your regular email address I will ask my wife to take a photo of my headlights with her digital camera and I will send it to you with dimensions. My email is [email protected]
Does your truck have a 3-speed trans?
I recently converted my '36 from 4.11 to 3.55 gears using a modified '37 Chevy car rear end and gears from a '51 powerglide equipped Chevy car.
Ray
Maplefrm, go the gallery, my 1936 GMC is there. Both Chevy and GMC used the 7 1/4 headlight. 1936 Internationals used them also. Show up on Ebay pretty regularly
1936 GMC T-14 1/2-Ton Pickup
The truck is has a 350 w/aluminum heads, headers, 3 dueces, automatic and a Ford rear end. I thought the headlights looked oversize and it seems I was right. This size is correct for the '32-34 Ford. The rear end has a very low gear and is unpleasant for highway use. Another thing to change.
Thanks for your help.
