8 members (C10 - C90 Bill, Donf, DoubleB, Otto Skorzeny, Gdads51, Hanks custodian, Forty9, 1 invisible),
40
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,020 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 9 New Guy | | New Guy Joined: Aug 2010 Posts: 9 | My '36 low cab has large chrome headlights. 10" across with 9" lenses and they about 8 1/2" deep. What are the correct size headlights? Thanks | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Do you mean what number bulb they use? You already gave the size.  If that was your question and it's still 6v the Filling Station lists this bulb for your application.
| | | | | Joined: Aug 2010 Posts: 9 New Guy | | New Guy Joined: Aug 2010 Posts: 9 | I believe that my entire headlight assembly is incorrect for this truck and that the orginal assembly used a 7" headlight and not a 9" headlight. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | maplefrm, take a look in at trucks like yours in the gallery and see if anything makes sense. Might try Keith Hardy's on line manuals to see if you can spot anything there. His link is in the tech tips. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Maplefrm, I have a '36 high cab that I have owned since 1965 and restored in the 1970s. I have no computer skills so I don't know how to post pictures here. If you give me your regular email address I will ask my wife to take a photo of my headlights with her digital camera and I will send it to you with dimensions. My email is [email protected]Does your truck have a 3-speed trans? I recently converted my '36 from 4.11 to 3.55 gears using a modified '37 Chevy car rear end and gears from a '51 powerglide equipped Chevy car.
Ray
| | | | | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | Maplefrm, go the gallery, my 1936 GMC is there. Both Chevy and GMC used the 7 1/4 headlight. 1936 Internationals used them also. Show up on Ebay pretty regularly
| | | | | Joined: Aug 2010 Posts: 9 New Guy | | New Guy Joined: Aug 2010 Posts: 9 | My email is [email protected]The truck is has a 350 w/aluminum heads, headers, 3 dueces, automatic and a Ford rear end. I thought the headlights looked oversize and it seems I was right. This size is correct for the '32-34 Ford. The rear end has a very low gear and is unpleasant for highway use. Another thing to change. Thanks for your help. | | |
