1 members (Hotrod Lincoln), 60 guests, and 0 robots.
Topics128,050
Posts1,055,641
#674677 09/01/2010 3:00 PM
1 Offline
I am in a little bit of confusion here as I start to rewire my '51 1/2 ton. It has been converted to 12 volts by previous owner years ago. Since then ,I have dismantled it to the frame ,and am now ready to put it back together. I bought a 10si one wire alternator with internal reg. Can anyone provide me with a simple 1 line diagram showing the complete starting and charging system, to include alt. batt, coil ,ign. switch,ballast resister, grounding ,etc. PLease make it as simple as possible . Thanks
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
You have not given enough information to answer all parts of your question: type of ignition key/switch, type of starter actuation (foot starter or electric solenoid starter), points ignition or electronic ignition(and type/brand). Changing to 12v and having an alternator right-away makes using all of an original wiring diagram very problematic.
Here is a diagram for wiring a one-wire alternator:
http://mightymo.org/public_html/images/Projects/DelcoOneWire/AmpMeter.jpg
from this website: http://mightymo.org/Proj_OneWire.html#Delco
1 Offline
I think it is the original key ignition, foot starter, points and a one wire alternator with out need for a DA plug. I hope this helps. Thanks
12v with ballast resistor in-line between the ignition switch and the coil?
