| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | I am in a little bit of confusion here as I start to rewire my '51 1/2 ton. It has been converted to 12 volts by previous owner years ago. Since then ,I have dismantled it to the frame ,and am now ready to put it back together. I bought a 10si one wire alternator with internal reg. Can anyone provide me with a simple 1 line diagram showing the complete starting and charging system, to include alt. batt, coil ,ign. switch,ballast resister, grounding ,etc. PLease make it as simple as possible . Thanks | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You have not given enough information to answer all parts of your question: type of ignition key/switch, type of starter actuation (foot starter or electric solenoid starter), points ignition or electronic ignition(and type/brand). Changing to 12v and having an alternator right-away makes using all of an original wiring diagram very problematic. Here is a diagram for wiring a one-wire alternator: http://mightymo.org/public_html/images/Projects/DelcoOneWire/AmpMeter.jpgfrom this website: http://mightymo.org/Proj_OneWire.html#Delco | | | | | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | I think it is the original key ignition, foot starter, points and a one wire alternator with out need for a DA plug. I hope this helps. Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 12v with ballast resistor in-line between the ignition switch and the coil?
