6 members (jmoore, joe apple, Gdads51, 3B, Rusted Nut, 68ironhead), 112 guests, and 3 robots.
Topics128,264
Posts1,058,350
Members48,485
#674822 09/01/2010 11:40 PM
I am looking for some help with my starter which suddenly stopped working. For some background, 6volt starter on rebuilt 57 235, 12volt electronic ignition, newer cables and all new wiring, new battery, new starter switch.
The last couple weeks it sounded like the the starter would take a second or two before it engaged and sounded different and was laboring a little. Then nothing when using the foot start. No sounds when cranking. That is when I replaced the 10 year old battery thinking it was the problem. Still nothing.That's when I replaced the starter switch. Still nothing when cranking. Do you think the starter is gone and needs rebuilding? I looked in the manual but nothing in there.
Got any ideas?
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
Blue 50 #674855 09/02/2010 1:48 AM
If you used the '57 flywheel with the 6V starter there is your problem. The teeth won't mesh.
Blue 50 #674864 09/02/2010 2:11 AM
RAK Offline
My starter went bad on my '58. When I removed it saw that the previous owner toyed with the teeth too make it compatible,but it went bad anyway.I took it to NAPA and got a new one which has been perfect with my 235 engine,cost around $100....Hope this is of some help?
Cletis #674867 09/02/2010 2:14 AM
The linkage may not be pushing the switch button far enough to make electrical contact. I had trouble with mine that way.
Return spring? Or lack of lube on shaft?
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
49 floyd #674939 09/02/2010 11:58 AM
49 floyd,
What return spring? On the armature? How do you lube the shaft?
(flywheel is '50, all linkage is working fine)
I have had the truck for 15 yrs and never had a problem with the starter. Is it possible to damage one by engaging it too long? I recently had it die on me in town and it would not start and I cranked it for quite a while until I found out the distributor cap was cracked.
Blue 50
1950 3100 w/57 235
Blue 50 #674945 09/02/2010 12:42 PM
Yes, a long cranking session can damage a starter, particularly a 6V model running on 12 volts. the "official" word is 30 seconds of cranking, followed by a 20-minute cool down period. Shorten the crank time, and lengthen the cooldown for one running at twice its design voltage. Starters run at nearly dead-short resistance, and the cranking current can be tremendous. As the speed slows, the back-EMF or counter-voltage drops, allowing the starter to draw more current. Don't ever crank an engine until it won't turn any more- - - -it ruins batteries and starters.
Blue 50 #674950 09/02/2010 1:28 PM
Originally Posted by Blue 50
What return spring?
Return spring pic
From Mr Denny Graham's web site
DADS50 #675066 09/02/2010 10:35 PM
Thanks for the picture Dads50, that's what I thought he was talking about. It is in good shape.
Hotrod Lincoln it looks like I cranked a little too long and burned it up. It was about 100 degrees outside when this happened.
I stopped by the ol boy in town that rebuilds these and that was his opinion too. Now I am trying to get that bottom bolt off so I can run it over to him for a rebuild. It has been a bugger to get off. Got it soaking with some PB Blaster.
Blue 50
1950 3100 w/57 235
Blue 50 #675098 09/03/2010 12:46 AM
Been soaking the bottom bolt with PB Blaster for 4-5 hours and that baby won't budge...doesn't help that ya can't get a socket on there only an open end wrench. Will a hand held propane Benzo put out enough heat to speed it along?
Blue 50
1950 3100 w/57 235
Blue 50 #675136 09/03/2010 3:13 AM
Whatever you do, you don't want to damage the housing. Maybe you should consider grinding the head off.
1951 1 Ton Completed
Blue 50 #675435 09/04/2010 2:47 AM
Would love to know what you find. I'm having the same problem, but I have replaced the starter with a used one and still nothing. See my post: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=675433#Post675433 for a description of my troubles, please.
Nick
Nick
1957 3100 Army Base Runner
Cenosillicaphobia
Blue 50 #675471 09/04/2010 4:43 AM
A common problem is worn busings causing the rotor to drag on the stator. It is possible to change the bushings yourself with the correct puller. Most shops can do this. I have developed a real mistrust for rebuilt stuff. This typically comes with grey hair.
Blue 50 #675573 09/04/2010 9:39 PM
Try a good dose of heat, followed by a shot of PB Blaster or Kroil, if any is available. Just don't set the truck on fire! Also, try tightening the bolt, then loosening it. Once the thread moves a little either way, it can usually be worked out. Use a good-quality open end wrench like a Snap-On, to keep from rounding off the nut.
Well I finally got it. Soaked with PB Blaster since Thursday and found a cheapo set of crowfoot heads today. A little cheater bar on the ratchet and came right off.
Get it over to the rebuilder on Tuesday morning and pick it up later that day.
Blue 50
1950 3100 w/57 235
Blue 50 #675630 09/05/2010 2:22 AM
The best thing to do is hot wire the starter and see if it spins. I should have done this before I bought one from the salvage yard. My old one works fine. The six gauge wire that runs from the battery to the starter was very corroded. I cut the end and reconnected it at the battery side and what do you know a working truck.
Nick
Cenosillicaphobia
