1 members (RBs36), 172 guests, and 5 robots.
Topics128,078
Posts1,056,049
Members48,433
#67439 10/20/2006 1:12 AM
I tore down my 1406 Edelbrock today. I screwed up one of the jets so I'm going to have to buy another. I just don't know what size. One primary was .095. The other I had to drill out so I don't know what size it was. Here's the weird part. The secondaries were .096 and .098. Why would they be different size?
What size jets would be recommended for a 1406 on a 350 with auto for economy performance? I don't care about going fast.
#67440 10/20/2006 1:38 AM
cletis , would this be of any help to you..
#1406, 600 cfm, square-flange, electric choke (non-EGR)
CALIBRATED FOR FUEL ECONOMY
Designed for small-block and small displacement big-block engines, these carbs are recommended only for stock to Performer level applications. Match with an Edelbrock Performer or Performer EPS manifold and other brands of similar design. Calibrated 2% leaner than #1405. Includes both timed and full vacuum ports for ignition advance. Comes with: Metering Jets – Primary .098, Secondary .095; Metering Rods – .075 x .047; Step-Up Spring – yellow (4" Hg). Use our Carb Stud Kits #8008 or #8024 if needed
looks like 95 and 98 would be correct,, someone may have installed the 96 by mistake or the only one they have,,, I am no carb guy but this seems to be an answer to your question or close to it..later
Redryder pix
My Hotrod
#67441 10/20/2006 4:27 AM
That sounds like info I can use. Thanks Joker. Now I hope my FLAPS carries them.
#67442 10/20/2006 10:31 PM
Riding in the Passing Lane
I,ve got a jet kit for them. What size do you want? I,ll mail them to you. I,ll be at the shop tomorrow. I can mail them to you. George
1972 Chevy c10 Cheyenne Super
#67443 10/21/2006 3:08 AM
Thanks Wrenchbender, but I have a set ordered that should be in tomorrow I ordered .092s and .095s.
I went to the Edelbrock website and found all kinds of good info there but nothing specific about what works well on a stock 350. I think I was running rich the way the previous owner had it so I decided to de-tune it with .095 primaries and .092 secondaries. We'll see how that works.
#67444 10/21/2006 7:06 PM
The one I had was rich. I weaned it down but finally changed to a Q-jet.
#67445 10/22/2006 3:41 AM
I like it. It has plenty of pickup to suit me. I hope it gets better mileage. It was a guzzler before.
#67446 10/23/2006 7:34 PM
I'm at altitude, so I had to re-jet my 1406, made a difference.
Don't know where you are but Edelbrock does give info if you
are a ways above sea level...
'53 GMC "Ranger"
