Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (G508, dt235sd, DoubleB), 173 guests, and 4 robots.
Topics128,277
Posts1,058,441
Members48,490
#67433 10/19/2006 8:29 PM
What is the stock wheel size for a 3/4 ton 50 Chevy? If bigger than 16" would they be split rims? Is it a 6 lug pattern?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#67434 10/19/2006 8:44 PM
I believe the stock wheel size for the 3/4 ton was 15". It was a split rim and had 8 lugs. All AD 3/4 tons used 8 lug wheels.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#67435 10/23/2006 8:12 PM
My 1953 3/4 ton GMC is 15" & 8 lugs but it is NOT a split rim !
Therefore I was able to have the rims reversed out 2" !
For a better look & handling ! (Wider stance on the highway !)
'53 GMC "Ranger"
#67436 10/23/2006 8:46 PM
Jeff is correct. Stock wheel is a 15", 8 lug, 2 piece rim. (I want to say it's 7" wide, too, but I can't remember off the top of my head.)
Many wheels from later on in the 50s (1 piece rims) will work just fine, though, if you don't want to mess with the lock rings.
#67437 10/23/2006 9:20 PM
15x5.5, 17" was optional.
Bill Burmeister
#67438 10/24/2006 5:08 AM
Yep, just broke down five of them and they are stamped 15x5.50. I'm lookin at the spec sheet and Regular tires are 15" 6ply and Maximum is 7.50-17 8ply, front and rear.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
