0 members (), 140 guests, and 0 robots.
Topics128,260
Posts1,058,343
Members48,485
#672255 08/22/2010 10:40 PM
Has anyone had luck rebuilding the lever shocks on a 41/46 ?If so where did you find the parts.I have looked around for rebuild kits and have not found any places selling them.I have seen the conversion kits for tube shocks but I would like to keep the levers .
As always thanks for your help.
Longhorn #672264 08/22/2010 11:33 PM
Riding in the Passing Lane
I have filled a lot of them with fluid & they start working.
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #672271 08/22/2010 11:43 PM
haven't seen anyone supplying parts, but there is one place that will rebuild them ... as cren says, sometimes it's just lack of fluid that's the problem, try that first
Longhorn #672607 08/24/2010 6:51 AM
I took mine apart, not the levers, they are pressed on, and cleaned out the bit of sludge with solvent. Blew them out with air. Shake the arms side to side to see how the bearings are. Two of mine had a little bit of shake, but when they are in the installed position, they don't leak and seem to work fine. The '41 book says to always install a new lead washer, couldn't find them so just tightened them up, no leaks. See my post on the link pins and bushings though.
Opportunity is missed by most people because it is dressed in overalls
and looks like work. - Thomas Edison
1941 AL 3/4 ton 125-1/4 WB, bought by my Great Uncle Matt in 1942. Still in the family.
Ron Peterson #672644 08/24/2010 2:26 PM
I did exactly what Ron did and they work just fine 2000 miles on Michigan roads with no leaks so far
When refilling remember to allow some room for the fluid to expand when it gets hot.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #673976 08/29/2010 9:35 PM
Thanks to everybody
I sandblasted them then took them apart and cleaned the parts then cleaned the inside of the shock.Made a new gasket and filled them with oil and they work and no sign of leaks.Just have to paint them and put them back on.
Thank you again
Longhorn #674037 08/30/2010 1:59 AM
Hey longhorn what type of fluid did you use? I have single action levers on my 49 3100. Just for FYI. Thanks Floyd.
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
49 floyd #674048 08/30/2010 2:41 AM
Floyd
I used shock oil that I bought from the filling station,but I think you can use brake fluid also.
Jim
Longhorn #674115 08/30/2010 1:48 PM
Ex Hall Monitor
Ex Hall Monitor
I'd think hydraulic jack oil would work as well.
Tiny #674164 08/30/2010 5:57 PM
Nice job on Sweetie !!
Kip's41 #676037 09/06/2010 11:35 PM
Tiny, Dito on the nice job. Your car looks great.Can you give me a general idea on how much time it took? Thank you and again, GREAT looking car.
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
