1 members (Samantha), 45 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#673727 08/28/2010 7:47 PM
I have a 4 wheel disc set up in my 39 chevy.... Dual master cylinder is mounted below the floor... I bled the brakes and thought I did a good job... but now the pedal feels mushy and im not getting any air spurts when i bleed them...
Do I have to have the caliper below the master to bleed?
thanks
matt
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod
1937 1 1/2 ton Is in the driveway
Matt
Was it a new master cylinder?
Was all the air removed from the master cylinder when it was bench bleed?
Something to look at.
You should be able to successfully bleed the calipers as installed.
DADS50 #673738 08/28/2010 8:34 PM
Yes I bled it first.... All new lines and calipers
Matt
Something else to check is that none of the rubber hoses are failing and bulging when the pedel is pressed.
However, it is most likely there is still some air in the system closer to the master cylinder end... keep on bleeding and don't ever let the resivoir get down so low that it sucks air or you will have to start all over again.
72 Suburban K20 350/T350/HO52
dckdgrs #674110 08/30/2010 12:50 PM
if you continue to have problems try reverse bleeding.
it's almost a nessesitey on my motorcycle.
it ain't YOURS 'till it ain't stock!
1951 chevy 3100
Krash #674408 08/31/2010 3:15 PM
3B Offline
Hy fatboy0169, when master cylinders are mounted below the level of the calipers, they should have a 2 p.s.i. residual pressure valve installed in the line, this keeps the fluid from draining back toward the master cylinder, which creates a negative pressure inside the caliper, which may cause air to be drawn into the caliper past the piston seal, hope that helps.
3B #674417 08/31/2010 3:45 PM
You can also try real fast short pumps of the pedal. Keep the bleeders shut and just give real quick short pumps, this helps bleed the master and pull air out of the lines.
If you are worried about the height difference, jack up the body and let the axle you are working on hang lower then the master, reverse the jack stands to bleed the other axle. I have even parked on a steep hill so the fluid would tend to run to the lowest point.
Joe
Joe H #674435 08/31/2010 4:43 PM
3B is right on target.
Just to share a couple of ideas I recently read is tapping on the caliper while bleeding helps move trapped bubbles out. Another point I came across is when the caliper bleed valve is lower than the M/C you may UNBOLT the caliper from mounting and lower it a far the the flex hose will allow....ensuring the bleed valve is "clocked" at highest point of the caliper.
Not to stir a swarm, I also read that DOT 5 is sensitive to pressure bleeding..... for what it's worth.
Good luck
