Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Hotrod Lincoln), 60 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#673725 08/28/2010 7:45 PM
I have my 261 up and running... I timed it at TDC according to the book. Idling about 600- 650. Idles great... when i step on the pedal... sounds great... the problem is when i back off the pedal... Does anyone have any ideas?
I was thinking maybe a vacuum leak but that would be on acceleration i thought...
Any help?
Matt
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod
1937 1 1/2 ton Is in the driveway
Carter/weber 2 barrels forgot to add that
Matt
Matt,
Did you try to set the timing to maximum vacuum at idle?
Can you get your idle down to 500 rpm?
tclederman #673874 08/29/2010 12:59 PM
Tim
What is maximum vacuum idle?
im sure i can get it down to 500... Im guessing thats where it should be?
Matt
Matt,
Maximum vacuum at idle is the maximum vacuum reading you get as you slowly rotate the distributor in both directions.
You first set the idle speed. The idle speed might increase as a result of the above operation. So, you may want to reset the idle speed and repeat the operation in the first paragraph, above.
Attach the vacuum gauge to the wiper-motor vacuum-port on the intake manifold.
Thanks tim..... I will try
Matt
