3 members (jay d, 2 invisible),
54
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Anyone have a good source for speedometer correction adaptor gears?? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | http://www.speedometershop.com/rep-pag.htmI averaged odometer readings from 10 x 10 miles measured on an interstate at 60 mph. They made an adapter that has worked on both a stock 3-speed and a stock 4-speed - to within 1% accuracy. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | What kind of tranny are you using? How far is it off? Reading fast or slow? Are you sure you need an adapter? I corrected mine (T5) with a simple driven gear swap - just cost a few bucks. I've had good luck with the guys at www.thegearbox.org | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Thanks for the help guys.
I’m running the 41’s stock 4 speed, but have changed the ring and pinion from 4.56 to 3.38 I also have slightly smaller diameter tires. Over all I need to speed the speedometer up by 23%
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think that my adjustment was about 18% (3.55 rear conversion and ~31" diameter radial tires).
Finding a correct combination of drive/driven speedometer gears for an original 1941 4-speed transmission seems quite unlikely.
If the company listed by The Green Farmer can provide an adapter, its prices look to be very good (#54RA2 might have correct cable fittings). Give them a call. Ask if they can make an adapter for a specific % correction.
