Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 51 guests, and 3 robots.
Topics128,003
Posts1,055,244
Members48,418
#673535 08/27/2010 11:39 PM
Anyone have a good source for speedometer correction adaptor gears??
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
http://www.speedometershop.com/rep-pag.htm
I averaged odometer readings from 10 x 10 miles measured on an interstate at 60 mph. They made an adapter that has worked on both a stock 3-speed and a stock 4-speed - to within 1% accuracy.
What kind of tranny are you using? How far is it off? Reading fast or slow?
Are you sure you need an adapter? I corrected mine (T5) with a simple driven gear swap - just cost a few bucks.
I've had good luck with the guys at www.thegearbox.org
Sure the others are fine, but a guy that rebuilds instrument clusters suggested this one:
http://www.transmissioncenter.net/speedometer_calibration_______va.htm
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
Thanks for the help guys.
I’m running the 41’s stock 4 speed, but have changed the ring and pinion from 4.56 to 3.38 I also have slightly smaller diameter tires. Over all I need to speed the speedometer up by 23%
I think that my adjustment was about 18% (3.55 rear conversion and ~31" diameter radial tires).
Finding a correct combination of drive/driven speedometer gears for an original 1941 4-speed transmission seems quite unlikely.
If the company listed by The Green Farmer can provide an adapter, its prices look to be very good (#54RA2 might have correct cable fittings). Give them a call. Ask if they can make an adapter for a specific % correction.
