5 members (dt235sd, JW51, Eisenholtz, klhansen, Ponchogl), 105 guests, and 0 robots.
Topics128,051
Posts1,055,764
#67316 10/18/2006 11:11 AM
Sorry to ask this, but here goes. I've seen a lot of posts on the T-5 transmission and was just wondering: what is a T-5? Sure seems to very popular, but I don't have any idea what it is. My wife says that I think a Powerglide is "new-fangled"! Thanx for the info.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#67317 10/18/2006 2:01 PM
To start an answer to your question...it depends on what it's being put into, what your running for an engine, if you are contemplating towing, the Ring & Pinion ratio, the tire diameter you plan to run, and what speed you intend to "cruise".
The most popular T5's are from the mid-80's S10's from V6's with a 1st gear ratio of 3.76 and a final OD ratio of .72. They have 14 splines on the input shaft. These are classified as non-world class (NWC) transmissions and T5's up to 89 were mechanical speedo's, which are preferred. There are also World-Class (WC)T5's from Camaro/Firebirds that require a tailshaft modification to relocate the shift tower. These are differently geared (closer ratio) have a 26 spline input shaft and are normally more expensive to obtain. Most NWC T5's from a j-yard are priced from $150-250 and are identified (year/gear ratios) by a tag mounted on the Driver's side of the transmission. A typical 85 T5 TAG will read 1352-145. The numbers cast into the T5 case do NOT identify it's year or ratios.
There is a wealth of information on T5's in this site and "Inliners" (using the "SEARCH" function)which points out the necessary modifications to install behind a "bolt" and there are numerous folks that have successfully completed the installation.
Be advised that this is not a pure "bolt-on" install and although the modifications are relatively simple, it is not something to rush into without a GOOD DEAL OF RESEARCH.
My T5 install was relatively easy but you must do the modifications as outlined and should pay particular attention to selecting a R&P ratio that let's you maximize your T5's potential and meets your own personal needs.
The T5 opens up the potential of the little Chevy 6 and makes driving a real pleasure. I hope this helps getting you started on your journey.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#67318 10/18/2006 4:16 PM
i put a t-5 in my 54 about a year ago and wish i had done it years ago. btw mine was from 89 s-10. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#67319 10/18/2006 4:50 PM
use the search here on our site and find a lot of neat stuff
here is one about your question
click here
Redryder pix
My Hotrod
