4 members (fonz8261, Otto Skorzeny, King Kielbasa, 1 invisible), 90 guests, and 4 robots.
Topics128,077
Posts1,056,015
Members48,433
#67303 10/18/2006 1:53 AM
Help guys. frown What should I look for if this turbo 350 won't shift? I do have vacumn from the intake ok.Oil level is ok, it did set for 2years. Any ideals will help. Thanks
#67304 10/18/2006 2:42 AM
Governor may be stuck ? You can remove the round cover off the side of the trans. I beleve it is the driver side.Pull the governor out and make sure the gear is not damaged or the valve is not stuck.To check turn the gear to the up position.Squeeze the two weights at the bottom, you should see the valve move freely inside,clean and try it again.How much oil do you have in it ? Will hold 8-10 qts if the converter was empty.Good luck.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#67305 10/18/2006 3:12 AM
Anonymous
Unregistered
Anonymous
Unregistered
Same thing happened to me. The most likely cause is it does not have enough fluid in it yet. With the engine idling, check the fluid level. I had to add another 3 quarts before mine had enough fluid in the converter to enable shifting. It works fine now.
#67306 10/18/2006 3:26 AM
61, will I get any oil when I pull the governor out? I'll try some more oil tomorrow too, thanks for the info. wink
#67307 10/18/2006 3:30 AM
You will get just what is in the cover, not much more. As the others have said, make sure it really is full on fluid.
