1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67303 10/18/2006 1:53 AM | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | Help guys.  What should I look for if this turbo 350 won't shift? I do have vacumn from the intake ok.Oil level is ok, it did set for 2years. Any ideals will help. Thanks | | |
#67304 10/18/2006 2:42 AM | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Governor may be stuck ? You can remove the round cover off the side of the trans. I beleve it is the driver side.Pull the governor out and make sure the gear is not damaged or the valve is not stuck.To check turn the gear to the up position.Squeeze the two weights at the bottom, you should see the valve move freely inside,clean and try it again.How much oil do you have in it ? Will hold 8-10 qts if the converter was empty.Good luck.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#67305 10/18/2006 3:12 AM | | Anonymous Unregistered | | Anonymous Unregistered | Same thing happened to me. The most likely cause is it does not have enough fluid in it yet. With the engine idling, check the fluid level. I had to add another 3 quarts before mine had enough fluid in the converter to enable shifting. It works fine now. | | |
#67306 10/18/2006 3:26 AM | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | 61, will I get any oil when I pull the governor out? I'll try some more oil tomorrow too, thanks for the info.  | | |
#67307 10/18/2006 3:30 AM | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | You will get just what is in the cover, not much more. As the others have said, make sure it really is full on fluid. | | |
