2 members (Ole49GMC, Hush),
74
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 6 New Guy | | New Guy Joined: Aug 2010 Posts: 6 | I need the specifics about the rad. #3863109244 Is there a fact sheet available, or how should I measure the original so that PRC can send me a replacement? The rad goes with what I believe is the original 216 engine. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Is the original rad " shot ". I have stock rad in my '40, running a 327 SBC. I had rad flushed and checked over, added a pusher style elec. fan - it is able to keep motor at 190 in stop & go traffic. | | | | | Joined: Aug 2010 Posts: 6 New Guy | | New Guy Joined: Aug 2010 Posts: 6 | Yes sir the radiator is stock with the 216 engine. I want to replace the radiator with a new one. But it looks as if the only way to get an exact fit is to send the old radiator to whoever sells me a new one.
Walker Rad in Memphis or Griffin in South Carolina.
It appears the outlet valve which a 1.5 inch hose fits extends out and then 90 degree up but then curves 40 degree. I'm worried that a straight outlet valve standard on a lot of replacement rads will not work. even with a flexible rad hose. It just seems like the radiator shops would have the ability to get the exact specs for a replacement with out me sending in the original. Appreciate your interests, Carl | | | | | Joined: Aug 2010 Posts: 6 New Guy | | New Guy Joined: Aug 2010 Posts: 6 | The original is not shot. But I would like to replace it. But I would like the replacement to have the same specs(outlet valve to pump especially). I would like to get an aluminum replacement. The outvalve off the rad is the problem. The radiator shops are out of state and don't seem to have the exact specs to replicate the original. To complicate matters I need to replace the radiator support bracket. Thanks for your interest. Carl | | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | I just bought a radiator for my 39 from the Brass Works in California. They had one to use as a template. Real nice job just wish the top tank was narrower... But the inlet and the outlets are as stock. Core is a little thicker.
Matt
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod 1937 1 1/2 ton Is in the driveway
| | | | | Joined: Feb 2000 Posts: 5,233 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,233 | Bubba, if you choose to go with a aluminum replacement, you could always get the lower outlet changed by a local weld shop. They could weld on any outlet you want or change the one on there. I have seen that done with good success. Mine is a straight lower outlet, but since I run a 250 engine, it was easy for me to adapt. In fact the lower hose runs under and around, then over the top of the oil filter. I picked up about 3/4 of a gallon of coolant just in the hose!
Joe | | |
