4 members (Sjm, TexasJim50, Chris_Welch, 1 invisible), 103 guests, and 4 robots.
Topics128,267
Posts1,058,386
Members48,485
#672534 08/24/2010 1:03 AM
Am in the process of rebuilding a '55 235. Removed pistons today, two of them had 2 rings in one groove (second from top). They had a "normal" size ring along with a very thin ring in the same groove. Anyone familiar with this? Thank you, Scott
1954 Chevrolet 4400 1.5-Ton Dump Truck
1946 Chevy 1.5-Ton Dump Truck
1944 Chevrolet 1.5 Ton Dump Truck
1955 4400 Dump Truck
1951 2 Ton Stake Body
If this was the top ring, it would be a ring insert. Your top ring land gets the most wear and you can recondition the piston by reaming out the groove, getting it square again and installing a ring insert. However, I don't know what would be going on with the second ring groove unless for some reason it was damaged and they repaired it by the method I have mentioned.
