| | | Forums66 Topics128,161 Posts1,056,906 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | wish I could help you Indianajones but I can't. I would like to know the answers to your questions too because I will be looking for 2 of those in about 5 years
1938 Gmc 1/2 ton
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I can't say about what year it is but the guages seem to indicate just what you said. Somewhere around a 37-39. I'm sure someone else will be around soon to let you know. Traffic is a little slow on the weekends but just wait till Monday!!
Some area's to look for Vin tags is usually on the door post near the hinges, sometimes they are on the edge of the door near the door handle, sometimes they are on the firewall on the right side (drivers side for you) or perhaps they on the other side of the firewall since its right hand drive.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Jonsey - are you sure that's a GMC? Chevy and GMC grilles were the main visual difference in body styles back then and I believe Chevy was the primary GM truck exported to your area - all the right drive trucks originated in Canada, maybe assembled in Port Elizabeth if that GM facility was operative back then
Bill | | | | | Joined: Aug 2010 Posts: 9 New Guy | | New Guy Joined: Aug 2010 Posts: 9 | Thanks for the replies so far guys.
I am not 100% sure it's a GMC, as I have not located a VIN tag yet. From photo searches on the web, I have deducted it must be a GMC. The Chevy grille for the time looks much more different than the GMC grille, the Chevy grille has all horizontal bars. The other differences from the pictures I've seen is that it seems Chevy's have 5-spoke wheels, whereas GMC trucks have 8-spoke wheels.
From what I know the COE body style is very rare, and its unlikely that it was assembled in P.E. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Looks like a '37, or '38 Canadian Exported Maple Leaf COE. Very "RARE" ! might even be a Oldsmobile COE. | | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | It looks just like the GMC Coe I had a few years back. and it is prior to 1938 There is key parts that are GMC only designs.
are you going to restore this truck? Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Found an article in the ATHS "Wheels Of Time" Vol. 21, No. 5 with a story on Maple Leaf Trucks. Shows a photo of a Chevrolet Maple Leaf COE with the same all vertical bar grille as this one, & it is refered to as a HM series Maple Leaf COE. Article says truck should have Chevrolet insignia on the grille, but the ID tag will identify it as a Maple Leaf. a GMC of this same Vintage will have horizontal grille bars to each side. There's a '37 model GMC COE fuel truck in "THE Gallery". | | | | | Joined: Mar 2007 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 64 | Here's one advertised on craigslist in the Bay Area which appears to be the same vintage. Ad says it's a 1946 but the seller doesn't know for sure. http://sfbay.craigslist.org/scz/cto/1911801443.htmlnot mine. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy IndianaJones, I think that truck is a 1937 G.M.C., that is the first year of C.O.E. trucks in the G.M.C. line, two years before Chevrolet began their C.O.E.s. Being right hand drive only adds to it's rarity, I hope you can save it, good luck. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | We've got a good debate going on this one. Don't think this is a GMC COE fella's. I'm sticking to my asumption that it's a Canadian Export Chevrolet Maple Leaf. 1937 was the first year for production Medium Duty GMC COE's. 1934 was the first year for production Heavy Duty GMC COE's. 1939 was the first year for Chevrolet production COE's. When I first saw the photos, I knew it either had to be a exported Maple Leaf, or maybe even a Oldsmobile COE. but after looking up my Wheels Of Time issue, & seeing the article, with a photo of the Maple Leaf COE, I'm pretty sure that's what it is. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I believe Spanky called it: scroll down to Additions to Above = "Chevrolet-badged C.O.E. chassis debuted for export as well as in Canada [see below] in 1937 Model Year. It appears that these were supplied C.K.D. not from Bloomfield Boxing Plant, New Jersey, but General Motors Truck in Pontiac, Michigan and were very similar to G.M.C. and Oldsmobile C.O.E. trucks also built in Pontiac Plant. For 1937, as with export G.M.C. and Oldsmobile trucks Hercules Diesel engines were available as well as Chevrolet 216 cu in engines." Canada supplied all the trucks to that side of the world  Bill | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | The COE 00truck post in the San Francissco area is a '37-'48 style Heavy Duty GMC COE. It's actually a '37-'42 with the two smaller engine access doors. The later version up through '48 had a alligator hood,that split the grille in the middle & not the access doors. | | | | | Joined: Aug 2010 Posts: 9 New Guy | | New Guy Joined: Aug 2010 Posts: 9 | Hi Thanks to everyone, your comments are extremely informative. My intention is definitely to restore the truck, and I'm very excited to get it home and start searching for parts. I found a link to a picture of an Oldsmobile COE in Australia, which looks remarkably similar to my truck. http://coetrucks.t35.com/Olds.1.htmlSeems to me the debate now is, whether the truck is a Canadian Export Chevrolet Maple Leaf or an Oldsmobile. Could anyone please advise me on the location of the VIN tags on these truck, in order for me to confirm the model. Thanks again guys | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Good work Indiana. If you can find the ID plate on your truck, that will tell it all, weather it's a Maple Leaf, or Oldsmobile. Either one is extremly "Rare". | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Great thread and even cooler truck. I had no idea that there was an Olds COE. Indiana, hope you restore that truck and have blast doing so. Oh yea, don't forget to take lots of pictures and share them with us often!!!! Can't wait to see your progress.
Billy | | | | | Joined: Sep 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 99 | My '36 Maple Leaf had 2 plates on the driver side firewall in the engine compartment. 1 plate listed the GVW etc and the other had it been there had the serial #. Fortunately I have the paperwork. Hope this helps. | | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | the circles imprinted on the inside door trim is the same as my 39 gmc coe I had. and the dash looks the same. The hood openings look to be the style that was added to the hoods after 39 gmc's.
It is possible that if it is indeed a olds. then they could have used q's from other trucks of various years? Not unheard of.
| | | | | Joined: Mar 2004 Posts: 6,232 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,232 | IJ, I have Chevrolet Engine Serial Numbers from 1926 thru 1940 for USA built cars and trucks and your number doesn't fit anywhere... Take the floor pan engine cover off and see if the valve cover is stamped GMC or Olds...just a thought. Mike B  | | | | | Joined: Aug 2010 Posts: 9 New Guy | | New Guy Joined: Aug 2010 Posts: 9 | Thanks Mike B
I'd also like to know whether this model would have had a Chassis Number stamped somewhere? Where on the chassis would it be located?
Thank you | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Possibly on the left frame rail, near the left front spring hanger. | | | | | Joined: Aug 2010 Posts: 9 New Guy | | New Guy Joined: Aug 2010 Posts: 9 | By the way, the engine is not a flathead, from what I've seen on the internet, both the Olds 230 and Pontiac 223 Flatheads have intake and exhaust headers on the right hand side of the engine.
This engine seems to be a 2nd Generation Chevrolet 216ci Stovebolt 6.
Could someone de-code the "BFC748675" serial number? | | | | | Joined: Mar 2004 Posts: 6,232 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,232 | IJ, Serial numbers being stamped in the frame rail started about 1955. Mike B  | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Not on GMC's Mike. GMC was stamping serial numbers on the frame rails starting in the late '30's, to early '40's. Indiana, did you check on the firewall, just below the dash. GMC also would put an ID Tag there. | | | | | Joined: Aug 2010 Posts: 9 New Guy | | New Guy Joined: Aug 2010 Posts: 9 | I haven't been able to find ID Tags anywhere, including under the dash.
Thank you | | | | | Joined: Mar 2004 Posts: 6,232 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,232 | Spanky, I did not know that...seems weird that Chevy waited until the mid 50's to start stamping the frame. Mike B  | | | | | Joined: Aug 2010 Posts: 9 New Guy | | New Guy Joined: Aug 2010 Posts: 9 | According to this website, http://clubs.hemmings.com/clubsites/chevytalk/gmhistory/1931to1938.html, some of the COE trucks produced in 1937 had a Canadian Pontiac 224cu in motor, which was an enlarged version of the Chevrolet 216cu in engine. Could the "BFC748675" engine serial number fit in with the Canadian Pontiac 224 engine numbers? | | | | | Joined: May 2009 Posts: 3 New Guy | | New Guy Joined: May 2009 Posts: 3 | Lots of Mis-information here. The COE's like this were production models in 36--and the longnose versions -at least started appearing in 35. They were exported to GM factory in Belgum as chevy bulldogs--and I think to Australia and elsewhere as oldsmobiles. The right frame rail should have a chassis # stamped just behind the front leaf spring. The dash is 39 up style, and I think it has a 248 GMC motor. the book GM the first 100 years has pictures of a 36 longnose and coe with this cab. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I see alittle mis-information here, but not "Lots of Mis-information". | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Indiana, That pic of the Olds Forward control is great. Never knew anything like that was built. You learn so much here! Thanks all 'Bolters!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
