| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 6 New Guy | | New Guy Joined: Aug 2010 Posts: 6 | The 3 speed steering column in my 65 has a lot of slop in the top. Was wondering if someone may have a parts diagram for it so i could see what is missing or worn out. thanks, Bryan | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if you mean the steering wheel is 'mobile', the upper mast bearing is hooped, most vendors will have that, just have to pull the wheel and look right there at the top - if you mean the shift mechanism, there's parts available for that as well, there's a springy wire in the knuckle that might break .... your best friend will be the shop manual, also available
Bill | | | | | Joined: Aug 2010 Posts: 6 New Guy | | New Guy Joined: Aug 2010 Posts: 6 | i can move the steering wheel and it moves with the shifter also. Where can i find a shop manual? I see that there are plenty of 1965 supplement manuals on ebay but not just a 1965 shop manual. Are there any that are avaliable to look at on line? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the 63 manual is the "base" one then there's supplements for following years of the same series see here, careful about manuals off ebay, they sometimes go for more than new  .... don't know of any of the 60's manuals online but a member here has some info posted .... if the whole column is loose that'd seem like the support to the dash, but that top mast jacket bearing is commonly bad Bill | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I had the same problem on my '65. When I replaced the upper mast bearing it helped but it was still sloppy. Upon investigation I found the lower bearing was gone (it is a ball bearing, the balls were gone  ) and the shaft was severly worn, worn to the point of being scary! This post helps to explain the repair: http://67-72chevytrucks.com/vboard/showthread.php?t=399139Hope this helps!
| | | | | Joined: Aug 2010 Posts: 6 New Guy | | New Guy Joined: Aug 2010 Posts: 6 | I took it apart again today and it looks like it is missing the bracket that the turn signal switch screws to and also the little tabs that hold the bracket in place are broken and missing. Guess im on the search for a column now. | | | | | Joined: Dec 2008 Posts: 40 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 40 | I went through the same thing with mine. Two of the three tabs were broken off. I would highly recommend contacting Tony Smith: Tony Smith 4-5-6 Chevy Trucks 560 South 11th Street Kansas City, KS 66105 913-207-7789
I got one from him and it is in near perfect condition and for a very reasonable price.
Trey Wilkins -------- 1950 Chevrolet 3100 Five Window1954 Chevrolet 4100 Dumptruck (Sold)1957 Chevrolet 6400 Dumptruck1966 Chevrolet K20 Longbed Fleetside1966 Chevrolet C60 Grain Truck (Sold)In the Stovebolt GalleryMore pix on Photobucket | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I went through the same thing with mine. Two of the three tabs were broken off. I would highly recommend contacting Tony Smith: Tony Smith 4-5-6 Chevy Trucks 560 South 11th Street Kansas City, KS 66105 913-207-7789
I got one from him and it is in near perfect condition and for a very reasonable price. X2 The upper bonnet on my column was also screwed up and Tony fixed me up with the parts I needed. I hate to be a nuisance, but did you check the lower column bearing too as I suggested above? | | | | | Joined: Aug 2010 Posts: 6 New Guy | | New Guy Joined: Aug 2010 Posts: 6 | how much does a good column sell for? Yes I checked the lower bearing and it is tight. the upper is where all of the problems are. | | | | | Joined: Dec 2008 Posts: 40 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 40 | I checked a local junkyard and they wanted $125 for the whole column and $75 for just that steering mast jacket (the piece with the broken tabs), and that was if I took it out myself. If you just want the mast jacket you can probably find it for $40-$60 if you look hard enough. As stated above, in my experience Tony Smith had the best price for the best product.
