1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Finally started on the 56 3800. The truck was lengthened by the previous owner (not sure why). With the help of my buddy we detached and removed about 4' of the new fram rails to get the wheelbase back to the 135" like my 57 3800. I have a 9' bed to put on eventually. http://good-times.webshots.com/photo/2836295760101465522moNpAE | | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | wow... That LOOKS creepy. How far from the back of the cab did you cut? Did you us e a Plasma cutter?
Jeremy
| | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | The existing frame was already cut and the rear frame was new stock that slides over the existing. The 4' came off the new steel. The welds were ground down with a grinding wheel. I made some clean cuts on the existing frame with my jig saw. I don't have the luxury of a plasma cutter...maybe someday. | | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | I can't afford a plasma cutter either. I have become a big fan of the mini hand held Milwaukee band-saw. I use it for everything. I even clamp it in the vise to use it as a small band saw. can't wait to see your truck finished! | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Spent the weekend putting the truck back together. It went much smoother than I anticipated and looks so much better back to the original 135" wheelbase. Just have to re-attach the shortened brake lines and cut down the driveline to fit. Sorry the pics aren't the best but it's too hard to push back into the shop. http://good-times.webshots.com/photo/2839687210101465522kNGmTb | | |
