3 members (TUTS 59, WICruiser, 1 invisible), 125 guests, and 3 robots.
Topics128,090
Posts1,056,382
Members48,442
Reinstalled my transmission last night. Went to get the u-joint, bolts and cover that slides on the drive shaft and over the u-joint to seal it. When I got the cover, I noticed that the screw on ring seal that seals the cover to the drive shaft was missing. Now likely my 4yr old or 6 yr old was messing with it and lost it.
Question: What is the name of this screw on seal piece, and are you able to order it from somewhere?
Thanks for the help
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/
Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time.
Doing some searching, I believe the part is called a "Torque tube knurled nut", not sure though.
I think you are referring to the a part that looks like the dust cap at the right of the upper diagram on this page. (ignore the rest of that drawing - it is not showing the torque-tube bell/ball cover you are referring to)
Post a Parts Wanted Ad in the Swap meet. Maybe someone knows where the part can be purchased but I have not seen it sold as a reproduction part. I have seen/bought a reproduction ball/bell and it did not come with that dust seal (threaded collar "nut").
Or, try calling Jim Carter Antique Truck Parts (or, Bowtie Bits) - they might have a used part.
Can you post a photo of what ball/bell parts you have, so that we might be able to better respond about what you are missing?
tclederman,
Excellent! You know exactly what I am talking about. I will get a pick later tonight or tomorrow and post it and also do the swap meet thing. Thanks so much. Can't believe I lost the darn thing. Going to turn my garage upside down tomorrow.
You'll find it a few days after you buy a replacement.
Called some local junk yards... 5 hrs away ! They are shipping the Bell and Dust Cover to me... $85 though. Ouch.. Wasn't worth his time to just pull the dust cover. frown
tclederman,
You were right.... blush Found it. Turns out my oldest slipped it back on the drive shaft. Believe it or not.. It was the only place I didn't look! DOH!!! ohwell
Guess I have a extra set of parts now.!
