2 members (BC59, G508),
77
Mod | | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67155 10/14/2006 7:33 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | So i am changing my oil today on my '57 235 with aftermarket cannister on the manifold...got home with the Rotella oil and a new Napa #1100 filter and when I pulled out the old filter it is not the same. New Napa filter ia 4" diameter and the old one was 4.5" (WIX-51100). The old one fit flush in the canister....while the new Napa one has at least 1/4" space from the sidewall. Was the wrong filter in there to begin with??
Chuck :confused:
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | |
#67157 10/14/2006 9:05 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They should be the same filter. Wix makes Napa & Carquest filters & the numbers are the same except the first number. It may have been boxed wrong. The original equipment fiter is AC. It uses a 5/8 wrench on the cover bolt. The aftermarket filter was Fram. It uses a 7/8 wrench on the cover bolt. Sometimes this causes confusion at the parts counter as they take different cartridges. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#67158 10/14/2006 9:17 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Wrench, well looks like it should be the Fram, cause it has the 7/8 cover bolt. What's the correct part number for the Fram?
Joe, I'm going to try the smaller one anyway... pressure looked good, no leaks. How's things in 'ol Cahokia<
Chuck
Blue 50
#67160 10/15/2006 12:30 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I just drop a roll of toilet paper in the canister and forget about it.  Ya'll worry to much.
delete my account and pictures
#67161 10/16/2006 11:58 AM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Tab, you should know....being from TexAss
Blue 50
#67162 10/16/2006 1:16 PM | Joined: Aug 2003 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 108 | Tab, What's the best brand of TP to use for an oil filter? I can't find the fram C4 anywhere around here in the parts stores. Tyler | | |
#67163 10/16/2006 1:30 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Single ply or 2 ply Tab? :p | | |
#67164 10/16/2006 1:46 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | In reference to oil filters, thanks to Wrenchbender, I now know that my filter pot, which I assumed was a Fram is actually an A/C (5/8" top bolt). However, I am quite certain that I removed a FRAM filter and replaced it with the same.
My concern is that I've heard that it requires more oil pressure for pushing oil through the larger diameter filter and in my engine I want to maintain max pressure to my bearing surfaces. Am I possibly loosing additional pressure by running the Fram filter in the A/C pot? I've also been advised that plugging the filter (bypassing it) will give me 5-10 pounds additional pressure. At this point with my engine of unknown internal condition, I'd like to get some recommendations as to which way to go. I'm sure that there are others that are "between" complete rebuilds, who would appreciate some expert advice. Thanks in advance. | | |
#67165 10/16/2006 2:03 PM | Joined: Oct 2006 Posts: 8 Junior Member | | Junior Member Joined: Oct 2006 Posts: 8 | Tab...Were there ever tranny fluid paper filters (maybe Frantz?) Do big trucks use paper towels? Do people hang their extra Rolls(Royce) from the longhorn hood ornaments? They can TP a neighborhood pretty fast that way...both sides of the street if they drive down the middle of the dirt road topped out at 45 mph! Cheers, Rich | | |
