4 members (Hotrod Lincoln, Uncles51, G508, Chip O), 114 guests, and 3 robots.
Topics128,028
Posts1,055,413
Members48,422
#669325 08/10/2010 7:41 PM
I was told I should use epoxy primer then body filler, then epoxy primer, block sand, then primer sealer.
I'm a beginner just wondering if I could go with body filler first then epoxy primer.
thx any help appreciated
41 chev #669329 08/10/2010 7:49 PM
I'm also a beginner. I've been doing a lot of reading, and it seams that it is split opinions on this topic. Half the painters like to put on the epoxy on the bare metal for a protective layer to prevent the filler from absorbing moister and causing rust. The other half puts the filler on the bare metal because it is a much stronger bond, and say they have never had a problem with the filler absorbing moisture as long as it is sealed. What I did is put filler on the bare metal and level as much as I could. As soon as I put my epoxy on, that brought out more low spots that I missed. Then I put more filler on top of the epoxy where needed. So most of the filler is on metal, but I wasn't afraid of putting more on top of the epoxy. I guess I'll see what holds and what doesn't.
[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
davidn #669357 08/10/2010 9:22 PM
thx Dave I think that's what I'm gonna do
41 chev #669375 08/10/2010 10:39 PM
In the collision industry filler over bare metal is the standard, even thou some car makers say to retain factory warranty epoxy is applied first. Filler on bare metal has been the standard for around 30 years.
In addition, most filler jobs are never exposed longer then a day or two without being primed or painted. I can have a quarter panel cut off and a new one installed sitting in paint before the end of the day.
The home user, I highly doubt can finish a panel and prime in a day or two. Thats why you see epoxy been used first, its mainly because you are preventing flash rust from developing because you have metal exposed for long periods of time.
It has little to do with the filler absorbing the moisture but having bare metal exposed and starting to rust and you dont even see it.
In addition, filler sticks better to fresh epoxy then metal.
The half that says filler over bare metal are probably collision guys, the other half that goes with epoxy are probably resto guys. Sometimes what the collision industry uses and does is NOT the best route for a restoration. Collision is all about speed and often quality and durablity suffers, you want products and techniques geared towards that mentality?...Eric...Collision technicain.
P.S. all my work at home gets epoxy first then filler.
Currently working on custom metal and How to videos.
1949 and 1972 chevy trucks
70 chevelle SS455
Pictures of my work and projects
http://community.webshots.com/user/sevt_chevelle
I agree with sevt_chevelle. If we were in a shop, filler on bare metal would be fine, but at home where the wife is yellin' and the kids are cryin' you just don't have the time. I always use epoxy on bare metal then filler, more epoxy, then 2k. And here in Florida you have to spray any bare metal fast.
Good luck.
jomichael #669789 08/12/2010 6:55 AM
Big Bolt Forum Co-moderator
Newbie question.....what is 2k?
1948 Chevy 2-Ton
Super55 #669804 08/12/2010 11:44 AM
i would sugest that is it is bare metal u go with self eaching first then filler then epoxy
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
Many epoxy primers CAN NOT go over etch primer.
Plus you should never apply filler on top of etch primer.
2K is typically known as urethane primer or a primer used for block sanding...Eric
70 chevelle SS455
sevt_chevelle #669944 08/12/2010 10:12 PM
Learned that one the hard way.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #670022 08/13/2010 4:07 AM
Let me guess, the filler came loose, maybe even some rust underneath.
The chemicals in the filler's hardner attack the etch primer causing the bond to weaken gravely.
70 chevelle SS455
Super55 #670079 08/13/2010 12:00 PM
2K is 2 part.
sevt_chevelle #670081 08/13/2010 12:40 PM
Let me guess, the filler came loose, maybe even some rust underneath. The chemicals in the filler's hardner attack the etch primer causing the bond to weaken gravely.
No doubt about it, you know your stuff.
Woody
Door Art Collection
what's best for cleaning/preping after the body filler is on and ready to be primired
41 chev #671497 08/19/2010 8:17 AM
I'm not sure what the best is, but I used a lot of air blowing things off, and a tack rag. I didn't want to use anything with moisture on filler, because I was thinking it would absorb and hold the moisture.
41 chev #671516 08/19/2010 12:17 PM
After blowing off all dust wipe down with a tac cloth then use a solvent cleaner designed just for that purpose and available at any auto paint store. If you want, a last minute once-over with a tac cloth wouldn't hurt for primer but is definitely best just prior to finish painting.
Woody
Door Art Collection
Czechman #671580 08/19/2010 7:32 PM
thx for the info guys,much appreciated!
Czechman #671617 08/19/2010 10:12 PM
After blowing off all dust wipe down with a tac cloth then use a solvent cleaner designed just for that purpose and available at any auto paint store. If you want, a last minute once-over with a tac cloth wouldn't hurt for primer but is definitely best just prior to finish painting. [/quote]
Is that solvent cleaner the "wax and grease remover". Or is there some other type of prep?
1948 Chevy 2-Ton
Super55 #671652 08/20/2010 1:10 AM
Yes a solvent cleaner is wax and grease remover like PPG's DX330 or you can use the water based DX103.
I use water borne cleaner.
70 chevelle SS455
