1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | The 58 GMC I have has a 235 in it instead of the 270. The mount on the front of the 235 is not all there. Looks like the PO cut a square plate and bolted it to the cross member then just bolted the front mount from the engine to this with a rubber pad between it and the plate. I've ordered the motor mount and the shield from Jim Carter because I'm going to need it. Was the 270 block shorter than the 235. I'm trying to figure why the PO used this plate. I havn't pulled the engine yet, that's next on my list. Figured I'd do that before putting the front back on the truck. Any insight you guys can give me would make my next move a little easier. Thanks in advance Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The GMC engine is about 1 1/2" longer than the Chev.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Thanks. Hopefully the plate is bolted to the original holes for the 270 mount. I guess I'll see this weekend.
| | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Yeah I did. Checked that out couple of times. I ordered the mount and the shield. I think I'll be having to fabricate the other part making it a little wider or longer to take up the extra space due to the different length of the engine. I'd like to make better than what the PO left me. Larry
