3 members (Hotrod Lincoln, dt235sd, klhansen), 111 guests, and 2 robots.
Topics128,127
Posts1,056,679
Members48,452
#671301 08/18/2010 4:17 PM
I have a fellow that wants to buy the 4 speed (with granny gear) that was original in my ’53 Chevy 3600. He has asked me who the manufacturer was and the model name of the transmission. He asked about Saginaw. Can anyone help out here from this limited information?
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
Hey John,
It's maybe a SM420, Does it look like this?
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I don't have it with me as I am having a new T-5 and rebuilt 235 installed about 2 hours away. I'll check when I go get it. I hoped that the '53s were all the same.
More information on the Muncie SM-420
This was the only 4-speed transmission available from the factory on any 1953 Chevrolet truck.
I said maybe because it may not be "from the factory". The Jeep guys love those SM420 transmissions. Check your local want ads if you need to set a price on it.
1953 Chevrolet 3600
Who made the SM-420?
The answer lies in the links provide by Tim and myself. Click on the Blue words in the posts, they are links to helpful information.
1953 Chevrolet 3600
GM made'em all - if the guy is looking for a "saginaw 4 speed" and thinking one might be in a 53 truck, he doesn't really know what he's looking for wink
He said that he was indeed looking for a SM-420. Now my question gets to a new level. My truck is a 3/4 ton and has an enclosed front propeller shaft. When that is removed from the back of the transmission, it would appear that for the transmission to be used for "open drive shaft" applications, it would need a different universal front flange and oil seal. Am I correct in assuming that the oil from the transmission presently flows back and fills or lubricates the enclosed front propeller shaft, or is the rear oil seal the same for all of these SM-420s and all that would be needed would be a different universal front flange?
The transmission's rear cover for the enclosed driveshaft would need to be replaced with the rear cover for an open driveshaft.
There is a seal in the open-driveshaft rear cover.
I take it from the shop manual (http://chevy.oldcarmanualproject.com/1929_54chevyparts/04/220.HTM ) that it is called "transmission rear bearing retainer 4.317". It appears that an oil seal goes into it and then the universal joint front flange passes through the oil seal. Do you know if the universal front flange is the same for my enclosed system or different for the open drive shaft?
Thanks for all of the help here.
