4 members (Hotrod Lincoln, cmayna, Youngin' Tut 59, Oswald), 86 guests, and 4 robots.
Topics128,180
Posts1,057,153
Members48,464
Does the fender to body bead on the rear fender also go between the fender and the side step? If it does is it done in one piece?
My truck did not have this on it when I started the body off resto, so I have no reference for this.
Thanks Dan
I've never seen a TF step bed with any beading behind the fenders
the reason your truck didn't have beading on the step joint is there wasn't any used - got an assembly manual? section 1 sheet 144 shows not any used on the fender to bedside either, just "underbody protective coating [6.5oz] - 1/8 bead entire length of joint"
only have assembly manual for 54 truck, maybe it is the same,is "underbody protective coating [6.5oz] a calk type material? My truck had been repaited and had a 1/16 or less gap from bed to fender that just looked like a place for rust to collect. what would be normal. I am in the final fitting stage and can make adjustment now before paint.
