9 members (sron48, rfs56trk, Mike in Sycamore, Nick in Manitou, Otto Skorzeny, Bill Hanlon, Charles in CA, 2 invisible),
99
Mod | | | Forums66 Topics128,136 Posts1,056,745 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | Does the fender to body bead on the rear fender also go between the fender and the side step? If it does is it done in one piece?
My truck did not have this on it when I started the body off resto, so I have no reference for this.
Thanks Dan | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I've never seen a TF step bed with any beading behind the fenders
the reason your truck didn't have beading on the step joint is there wasn't any used - got an assembly manual? section 1 sheet 144 shows not any used on the fender to bedside either, just "underbody protective coating [6.5oz] - 1/8 bead entire length of joint"
Bill | | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | only have assembly manual for 54 truck, maybe it is the same,is "underbody protective coating [6.5oz] a calk type material? My truck had been repaited and had a 1/16 or less gap from bed to fender that just looked like a place for rust to collect. what would be normal. I am in the final fitting stage and can make adjustment now before paint. | | |
